ok here goes its been awhile since ive done any installs and i just got an indash screen so imma need some things again
1).. Cavalier wiring guide for 1996
2) Which is positive and negative.. wire with line or without line?
3) ......Damnit forgot 3rd ? ill post it when i think of it again
i got it..
3) since my screen has a "video output" and if i want to eventually put tv's in the visors am i able to split that line? and also where can i get thin enough lcd's without getting all new thinker visors?.. thanx in advance..
no one can answer my simple ?'s??
2) stripe is normally negative
as for the other ones, you'd just have to do some research. should be able to find some of it on here with some searching.
here
This site should give you the wiring diagram.
3) yes you can, but you'll have to run some RCA cable through your dash, up your A-Pillar, through your headliner, into the visor, and you'll still see the wire on the arm of the visor.
Unless the video out isn't RCA, in that case........get an adaptor so it is.
Ads by Sk88
Saskatchewan J-Body Club
A club for J-body enthusiasts located in Saskatchewan,
as well as some other car enthusiasts.
www.saskjbody.org
1995-96 Chevrolet Cavalier Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
the video out is indeed RCA.. where do i get a splitter and wut is it called i would imagine its pretty cheap on ebay
