wire colors for lighting and horn? - Audio & Electronics Forum
Friday, August 19, 2005 6:53 AM
does any one know where i can get the wire colors for a 2000 cavalier 2.2, i am putting in an alarm and remote start and i need to know the colors and for parking lights and horn and starter and all that stuff, can i get it ASP iam putting it in tomarrow. thanks
Re: wire colors for lighting and horn?
Friday, August 19, 2005 9:18 AM
parking lights are brown. horn check the passenger wheel well or the relay under the steering column. starter i have no clue
Friday, August 19, 2005 9:27 AM
2000 Chevrolet Cavalier Security Information
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness PCM and Cluster
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White Harness in Front of Engine
Neutral Safety Wire Yellow Ignition Switch Harness
Brake Switch White Brake Switch
Trunk Release Black/White (+) OEM Keyless Module Driver's Side of Trunk
Trunk Pin Black (+) Light in Trunk
Parking Lights Brown (+) Light Switch
Head Lamp Dark Blue (-) Pink (-) at Head Light Switch
Door Trigger White (-) Module left Side Dash above Driver's Kick
Door Lock Light Blue Either Kick Panel (Passenger's Switch is Master)
Door Unlock White Reverse Polarity
Driver's Lock Gray Left Kick Panel
Driver's Unlock Tan Left Kick Panel
Passenger Unlock White Left Kick Panel
Horn Wire Dark Green Horn
Windows Up LF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows Down LF=Brown, RF=Tan, LR=Purple, RR=Purple
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, August 19, 2005 9:36 AM
^^^much better than my description
