Suggestions on Sub Box for 3 10"S - Audio & Electronics Forum
Thursday, August 18, 2005 10:23 AM
Alright, I bought 3 10" RE RE subs. I know they are entry level, but i got a really really good deal on them. I am shooting for 3 cubic feet and wondered if anybody else has built a box for the cavy for 3 10s. Its going to be im guessing 36" long x 20" deep x 14.5" high, or what dimensions did you use?
Re: Suggestions on Sub Box for 3 10"S
Thursday, August 18, 2005 11:09 AM
36 wide x 14 tall x 17.5 deep will give you 3 cubic feet internal.
Beat it like it owes you money
Thursday, August 18, 2005 11:21 AM
Sweet. So i suppose i will do 19" deep to make up for the 3/4 MDF for the port?
Thursday, August 18, 2005 2:53 PM
Good to see you went with RE, you definitely won't regret it. Once you get the box finished post up your results.
I think if you call RE (or e-mail) they can give you box spec's too.
Thursday, August 18, 2005 5:43 PM
hmm..three ten's..tell me the displacement of one of those and i'll tell you some ported specs you could go with.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Thursday, August 18, 2005 6:27 PM
hmm...
htttp://reaudio.com
Then go products, subs. Its the entry level model RE. You should be able to find it there... if not let me know, i can find it and list it for you.
Thursday, August 18, 2005 6:37 PM
Here is the information listed on reaudio.com
Fs ~ 21.5 Hz
Re ~ 3.2DVC
Qms ~ 4.37
Qes ~ 0.39
Qts ~ 0.36
Sd cm2 ~ 322
Vas ~ 75.6
Xmax 1 way ~ 12mm
Thursday, August 18, 2005 7:12 PM
yea man...i'm WELL aware of the specs. but they don't list the displacement of the sub.
you need that in order to design the box properly.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Thursday, August 18, 2005 7:56 PM
Mr. Loki on caraudio.com said to build it like this...
14 x 34 x 16
H x W x D
port size is going to be 2 inches wide, 12 inches high, 12.5 inches deep.
Thats going to be a total of 3.4 cubes of total air space and tuned to 34 hz.
Friday, August 19, 2005 4:17 AM
How are you going to wire three DVC 3.2ohm subs to a MTX 6500d? You're looking for 4ohms for each input, since the amp is internally bridged and "2ohm stable"..
"If life throws you a curve, pop the clutch and drift it!"
Friday, August 19, 2005 9:49 AM
Friday, August 19, 2005 10:50 AM
I assume the overall displacement is roughly 0.08 cubic feet for most entry level 10" subwoofers.
Check my sig for ported sub box designs.
Slot Ported Box Design Calculator
