my sub stoped working. so i took it out of the box and looked at it everything looked ok put it back in turned it on it went on for a few then it stoped again. and it keeps doing this. all the wires look like they are together.
could the problem be with the amp. did you check to see if the power light was going on in the amp when this happened, are you running to low an ohm load for the amp?
