Which Amp? - Audio & Electronics Forum
Which Amp?
Friday, August 12, 2005 4:35 PM
I need to decide which amp is better for my subs I am buying.
Dual 12" Audiobahn ABP12T
* 800W RMS Power Handling
* 1600W Max Power Handling
* 2 Ohm Mono / 4 Ohm Stereo Operation
* Sensitivity: 103dB
* 2" 4-Layer ASV Voice Coils
* Frequency Response: 25Hz - 140Hz
The two amps I am looking at for them are these...which one do you think would be best:
Audiobahn A8002T or Audiobahn A12005DN
Re: Which Amp?
Saturday, August 13, 2005 12:23 AM
*Bump*
Need an answer
Re: Which Amp?
Saturday, August 13, 2005 4:03 AM
get some info on the amps and you might get more help.
SO EVERYTHING!
Re: Which Amp?
Saturday, August 13, 2005 9:02 AM
The A12005DN is going to put out more power (600 watts) at two ohms, which you can wire youre speakers at, so that would be better. If those were my choices that is.
Personally if i were looking for 600 watts i'd go with an orion 600d (about $220 on ebay), and probably 2 jl audio 10w3v2 D4's and run the voice coils in parallel, and then the speakers in paralell, to get a 1 ohm load (you can find the speakers for $300-ish). I'd also build my own box. For $650-ish (after install costs etc) that'd be a pretty damn nice system.
Oh, by the way, i happen to have a box for 2 jl 10w3v2's.. if you're interested
Re: Which Amp?
Saturday, August 13, 2005 9:52 AM
Audiobahn A8002T 800W 2Ch Intake Series Amp
* Brand New Audiobahn A8002T 2 Channel 1600W Amp
* Class A/B MOSFET Power Amplifier
* 2 Ohm Stereo Stable
* MOSFET High Speed Switching Power Supply
* Non-Regulated Power Supply
* Double Sided Epoxy Circuit Board
* Air Induction Fan Cooled
* RCA (Low Level) Inputs
* Speaker (Hight Level) Inputs
* RCA Outputs
* Variable High Pass Crossover : 50Hz - 750Hz
* Variable Low Pass Crossover : 50Hz - 120Hz
* Variable Subsonic Filter : 20Hz - 50Hz
* 12dB Crossover Slope
* Signal to Noise Ratio >100dB
* 0.02% T.H.D.
* 18dB Bass Boost
* Bass Boost Control On/Off
* Phase Shift 0° - 180°
* 1/2/3 Channel Operation (Mixed Mono)
* Tri-way capable
* Soft Start Circuitry
* High Gloss Chrome Plate Finish
* Blue Illumination
* 4-Way Protection Circuitry: Thermal, Short Circuit, Overload, DC Offset
* 30A x 2 Fuses
* Dimensions: 11-1/16"W x 1-7/8"H x 11-7/8"D
* 2 x 200W RMS @ 4 Ohm
* 2 x 400W RMS @ 2 Ohm
* 1 x 800W RMS @ 4 Ohm
Audiobahn A12005DN 600W RMS Mono Class D Digital Subwoofer Amp
* Brand New Audiobahn A12005DN 600W RMS Mono Amplifier
* Class D Power Amplifier
* 2 Ohm Stable
* RCA (Low Level) and Speaker (High Level) Inputs
* RCA Outputs
* Mono Output
* Input Sensitivity: 200mV ~ 8V
* THD: <0.05%
* Variable Low-Pass Filter: 40Hz ~ 120Hz
* Variable Bass Boost Control @ 45Hz: 0 ~ 18dB
* High Gloss Chrome Plated Finish
* Cobalt Blue Illumination
* 375W RMS x 1 @ 4 Ohm
* 600W RMS x 1 @ 2 Ohm
* Dimensions: 11-1/16"W x 10-1/4"D x 1-7/8"H
Re: Which Amp?
Sunday, August 14, 2005 12:22 PM
I would recommend not using an Audiobahn amplifier. If you do, use the A12005Dn because it is a class D amp made to power subs. The fan is very loud on the intake series amp and because it is a 2-channel amp your going to lose a lot of power. I ur intrested I have an Orion 600D that would power those JL's....
Re: Which Amp?
Tuesday, August 16, 2005 10:46 AM
Hey man, this could be a great deal for you. Jard's 600d, i forgot, i also have one of my JL 10w3v2's, and the box. All you'd need to do would be get one more jl, and sound wire to install it. Sounds like a sweet deal to me.
Re: Which Amp?
Tuesday, August 16, 2005 3:51 PM
The subs you're getting are dual 4 ohm, which means you can run them 1 ohm, 4 ohm, or 16 ohm.
Beat it like it owes you money
Re: Which Amp?
Tuesday, August 16, 2005 11:25 PM
I ended up going with the subs and Class D amp...got it today and should have it hooked up soon
