stuff stopped working suddenly.... - Audio & Electronics Forum
Friday, August 12, 2005 7:09 PM
ok i did a search about amps and things not working and i didnt find exactly wha ti wanted but... heres the story...
i was sittin int he car jus tlisteing to music cuz i was bored... i had it pounding for a minute just to show off fer the girls...(childish i know).. and then it got turned back down low and about 5 minutes after everything wired to the amp is dead not working at all.... i have 2 6x9's and a 2 subs on this 4ch amp and its just not working.. i dont think its blown but i think the amp is toast is all i can come up with and yeh ill probly get flamed for this but i have a sony 500W amp and the subs and 6x9's add up to about 600W rms so im figureing it was just working too hard but still it worked for a long while until some dick put my bass setting up too high soo anyone have any suggestions or reccomendationds for amp/s??
"this is only the beginning"
Re: stuff stopped working suddenly....
Friday, August 12, 2005 7:20 PM
you have 2 subs running off at 500watt amp? and i am assuming its peak watts and 6x9s yeah your amp is prolly toast, but it may not be the case so dont quote me
hmmmm.... I am confused, and the Blonde genius that is me,
does not easily get confused
Friday, August 12, 2005 7:21 PM
well is the amp turning on. Trouble shoot.
Amp isnt on. Are you power and ground solid? is a fuse blown? Inline or in the amp...ya gotta give me some more
Saturday, August 13, 2005 4:49 AM
fuses are fine wires are all solidly attached power,ground,remote,rca's,and im not sure if its turning on ill look today
Saturday, August 13, 2005 9:00 PM
how many speakers you have wont make a diffrence as long as the speakers are wired in a ohm load that the amp can handle. you could have 5000 watt speaker on there and the amp will not play harder because of it.
check the power light and see if it has any protection type light.
Saturday, August 13, 2005 9:06 PM
i jsut ment that was a lot of stuff to have running off one 500watt amp
Monday, August 15, 2005 5:33 PM
Hey man put a different fuse into the fuse holder...ive got the barrel kind of fuses that i got from circuit city and they look like they arent blown but they have a bad connection, i finally went and bought some new fuses and it works just fine now
