quick DRL question - Audio & Electronics Forum
quick DRL question
Saturday, August 06, 2005 5:50 PM
cyklone wrote:How To: Disable Daytime Running Lights (DRL) on 2000-2005 J-Body Vehicles
2. There are 2 Blue plugs and 1 smaller Purple plug plugged into the BCM. Unplug the middle one by pulling back the blue tab. It will slide right out.
IT DOESNT SLIDE RIGHT OUT
any tips lol? or can i just cut it while its plugged in?
Re: quick DRL question
Saturday, August 06, 2005 8:20 PM
lift on the tab and pull???? i pulled mine like 5 times that way, just pull up on the tab and pull that sucker out of there
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Saturday, August 06, 2005 8:39 PM
Pop the BCM out of the plastic holder by pushing apart the two plastic tabs on either side.. then you can pull the BCM out more and get a good grip on it.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/misc/redsig.jpg"></a>
Saturday, August 06, 2005 9:02 PM
you can just cut it without removing it but....i had an easy time getting it out
Sunday, August 07, 2005 12:22 AM
are you sure i will have no problems cutting it while its plugged in?
Sunday, August 07, 2005 9:33 AM
nah, jus tbe sure the car is off...................its probably better this way...cause i had to reset my radio clock when i did it
Sunday, August 07, 2005 10:26 PM
wh i gueaa
Sunday, August 07, 2005 11:34 PM
I did this just the other day. Just simply take out the second pin connector. Besure not to cut the wire to short so you can ground it in a good spot. If you do cut it short soder (sp?) a longer piece to get it grounded.
Monday, August 08, 2005 1:23 AM
yea thats not my problem
i cant get the damn clip out, i swear its glued.....
im asking if i can cut it while its connected
Monday, August 08, 2005 7:43 AM
Yes
Monday, August 08, 2005 11:17 AM
Yes you can, just make sure you have the right wire.
You're reading my line-break, you are a loser.
Monday, August 08, 2005 1:13 PM
why disconnect drl
Sinister Ambitions
when your girl is getting on your last nerve f*#k her dont fight her
Monday, August 08, 2005 1:53 PM
^^^^some people like to
Tuesday, August 09, 2005 12:33 AM
the only blueish one from the middle clip lol
