is 1 enough? - Audio & Electronics Forum
is 1 enough?
Monday, August 01, 2005 7:17 PM
after asking around, i decided to get 100 ft. of fatmat off ebay. its scheduled to be here soon....and i was wondering if one later throughout the car is enough? is there going to be a dramatic difference? would 2 layers be necessary? or over kill? or would i be satisfied with one layer throughout the car? and is 100 ft enough for the entire car? if not, i'll do parts like under the carpet and behind panels..then save the trunk for another time bc it would be easier to do...vs. taking out the whole interior-
thanks
Re: is 1 enough?
Monday, August 01, 2005 7:56 PM
100 square ft, i assume, then yes its enough for 1 car, and you will even have some left over.
As for if you should double it, I dont know, what system are you running?
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Re: is 1 enough?
Monday, August 01, 2005 11:22 PM
i have 2 12" sony xplods in the trunk, then pioneers in the doors. one main reason i got the sound deadening is to cut down on "outside" noise, like the road and all that, so the quieter the better. lol-
Re: is 1 enough?
Tuesday, August 02, 2005 10:49 AM
id personally go with 2 layers over the areas that need it most. only you can decide if its enough, i used around 350sq. ft. of damping material. and at close to 140db its quiet enough that u barely hear the bass from 5' away.
Re: is 1 enough?
Tuesday, August 02, 2005 9:56 PM
what kind of sound deadening did you use?
Re: is 1 enough?
Tuesday, August 02, 2005 11:22 PM
i used fat mat they all pretty much do the same job its just depends on how much u want to spend
Re: is 1 enough?
Wednesday, August 03, 2005 3:11 PM
i used stuff from parts express, i think the fat mat is a bit cheaper.
