Well i just installed a new yellow top and got my terminals working finally.
Well there is a small ground wire coming off the + battery terminal for the voltage gauge, but i dont like seeing it where it is, I wound like a few suggestions, if possible on ways to hide it.
My cone filter will be where it should be in about a week, if everything goes well, but i just dont like the black wire just sitting there on a yello backround.
BTW its not the same wire as the one on the lower right side, im moving that one too, to a less exposed ground point.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
rrrr, damn Photobucket, or mee, lets try that again...
thats an interesting place for a volt gauge...
98' Pontiac Sunfire SE
just tuck it under and run it right along with your stereo power wire until it's down and out of the way.
much like i have done here..
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
wysiwyg wrote:just tuck it under and run it right along with your stereo power wire until it's down and out of the way.
I didnt even think about that. Cool, thanks.
But wouldnt it be a problem running a ground wire directly next to a much larger power wire.?
My batterys in my trunk so i dont have those wires. only had to run 1 amp wire from the head unit to the back of the car too
oh yea i got a cobalt
Gary Smith wrote:My batterys in my trunk so i dont have those wires. only had to run 1 amp wire from the head unit to the back of the car too
So without your stock wires, How do you start your car?
Cobalt comes with the battery in the trunk... stock.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/misc/redsig.jpg"></a>
