Deck keeps cutting out - Audio & Electronics Forum
Thursday, July 21, 2005 2:12 PM
I dont have the slightest clue on whats going on, I had Best Buy install a JVC KD-LH3100 and when I turn it up too loud then it will cut out and shut off and back on real quick. I hve 2 12" subs at 450w a piece and a 1200w 4-channel amp and the subs are briged. Some people have said I might need to run a direct power wire from my cd player to the battery, and others have said that I am over-powering my subs...Any help would be great. Thanks, Mark Brown
Re: Deck keeps cutting out
Thursday, July 21, 2005 2:19 PM
it sounds like to me that u need to run a direct power wire from ur stereo to ur cd player.
"Signature"
Thursday, July 21, 2005 10:26 PM
mine does the exact same thing... im also over powering my sub but i dont think that would effect the deck. my deck cuts off with the subs on or not. It happens at high volume though. I had mine installed at circuit city. I asked a local shop audio express over the phone what they thought and they said possibly a speaker or two of mine were "taking dumps" like shorting out at high volume. BUt it does it on all 4. It just seems when the deck needs more power it takes a crap. I thought maybe i have a bad ground or something. Because i know amps turn off with bad grounds. Any ideas?
98' Pontiac Sunfire SE
Friday, July 22, 2005 10:39 AM
^^^ exaclty what mine is doing
Friday, July 22, 2005 1:22 PM
ack i hate this problem, hella sucks when your showing off and it does it
Saturday, July 23, 2005 4:07 PM
yeah, it sounds like you need to run a direct line to your battery as well as a switched power source. what HU are you running, I know I had to run one for my alpine 9833. make sure you stick a fuse in there too
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
Friday, September 02, 2005 6:54 AM
Mine does the exact same thing. I am not a wiring Guru so what do i need to do.
all the time
Saturday, September 03, 2005 6:45 PM
seems to be a common problem, mines been doing it too, I hate it. If anybody knows, please share your knowledge.
Saturday, September 03, 2005 8:35 PM
Run a fuse tap from your HU to the fuse box. Make sure you use thick enough wire.. I think I used 14 or 16 awg
Saturday, September 03, 2005 10:24 PM
Check all the wireing to make sure that no bare wires are sticking out of the bundles. Stock wire harness is good enough for all but the most extreme systems.
Monday, September 05, 2005 4:06 PM
i had the same problem what realy is happening is your under powering your speakers and your deck cannot give any more power so it shuts off. Try putting it on only front or rear speakers and see if it still does it if it does you probly need an external amp for your door speakers if thats not it idk what to tell you
