Rear Speaker Wiring Harness - Audio & Electronics Forum
Saturday, July 16, 2005 2:25 PM
Does anyone know what the 4 wires out of each rear stock factory speaker are for? I just installed new ones and just connected 2 of the 4 to each but am wondering what the other 2 are for and if they should be connected.
Re: Rear Speaker Wiring Harness
Saturday, July 16, 2005 2:28 PM
The amp. Some cars came with a stock OEM Amp.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Saturday, July 16, 2005 2:29 PM
Lawnmowerracer wrote:The amp. Some cars came with a stock OEM Amp.
Correction, i believe.
Its been talked about so much in the past, but i never paid attention, i dont have the monsoon system.
Saturday, July 16, 2005 3:28 PM
OK so how do I wire it up then? Cause I definitely want that hooked up
Saturday, July 16, 2005 5:14 PM
it's low pass and high pass. on the stock speakers one set is for the tweeter, and the other for the woofer.
if your using an aftermarket deck, you only need to use two of them.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Sunday, July 17, 2005 5:23 PM
If its the stock deck though, do I need to connect 2 of the wires from the deck to both the positive and negative of the after market speaker?
Monday, July 18, 2005 6:03 PM
Anyone know how to wire this correctly?
Thursday, July 02, 2009 3:02 PM
has anyone ever figured this out. I have the monsoon system. I cannot find a wiring harness for it to install new 6x9s. If you only hook up 2 wires they work but not loud at all. As if they have no bass. If you hook up all 4 it looks like its going to fry the speaker in seconds. Anyone????
Thursday, July 02, 2009 4:54 PM
I think in my sticky it says which wires to use if you have monsoon.
Sunday, July 05, 2009 8:46 PM
i had a camaro with the monsoon system all 4 speakers had 4 wires going to each, so i got fed up and just ran my own wires from my head to each speaker
Wednesday, March 13, 2013 9:20 PM
i have the SAME question and cant find it anywhere
