15" RE XXX spl box dimensions - Audio & Electronics Forum
I have 1 15" re xxx in my cavalier. Its a slotted port box to spec tuned at 30hz. When i went to compete in dbdrag people were telling me the box and port were to small. my internal volume for the box is 4cuft. I want to make a box just for spl for this sub so i can compete in dbdrag. Im using a dual 2ohm sub run by an eclipes da7232 amp
http://www.eclipse-web.com/amp/da7232.html . I hit 138db playing 38hz. I know this sub can be louder any help would be appreciated. The sub is firing to the front of car.
You should be using a dual 4ohm sub for a 2ohm load to get the maximum from your amp.
09 HHR LS, Wife's Car
05 Cavalier, Clarion DXZ375MP, Autotek MM8000.5 & 13Kv.2, wife's old car, updates coming soon
each channel is wired to each coil. the amp isnt bridgeable. i dont know much i just pay people to do all the installation
if your building the box JUST for burps in comp. then you need to tune it so it peaks at the resonant frequency of your car.
how much port area do you have? i'd hope at least 40 or 50 sq. in"
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
how do i figure out the port square inches. i can meausre the box quick and get back to you in a few mins.
length X width of the port opening.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
57.75 port. its 19 1/4 by 3
i did a db drag event this past weeknd and asked what my highest freq and we ran a sweep from 30 hz to 70 and 38hz was the highest. I hit a 138. 9 i know this sub can do better than that.... my 12" l7 hit louder than this but the re xxx sounds louder and more clearer than the kicker
it's probably the enclosure if you think your not getting as loud as it should be.
tune it higher and i'm sure you'll see a gain
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
how would i go bout doing that? the box was made to re specs internal is 4cuft external its little over 5 cu ft
shorter port....should raise the tuning.
hell i'd just build a new box made for contests...keep this one for daily
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
thats what im planning on doing... my sound quality in unbelievable. this is the best sub ever purchased. if im going to make a new box what internal volume and port would u recommend
hey im the one from termpro that told you to check this site out.
if your going for spl olny get a box with 5-6 cubes after displacment and 70-80" of port. face the sub into the car and seal off the trunk that way you have less space and that will give you a higher spl.
i had a singe se 12 hooked up to a 280 watt amp and i did 139 at 48HZ so you have alot of room to work with.
Dang Mark, now you're bringing them over here. Hopefully we don't scare them away.
Mike Roth
The system has arrived.
you say 5 - 6cuft after displacement. which means what? my box in the car rights now is external of 5.05cuft. with 57 3/4 of port. the box is firing the way you say to fire it.
yea yea i know
i mean internal not external over on term pro you said the box is tuned to 30 hz also that can have alot to do with it.
do you have your trunk sealed off of is the box just facin into the car?
its not sealed off but the spl box im gonna make will be sealed off...
yea...i'd tune it higher for compeittion.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
also what kind of amp /amps would u run this sub. i have a dual 2ohm. in ur video what is that orion amp u using
douglas hutnik wrote:also what kind of amp /amps would u run this sub. i have a dual 2ohm. in ur video what is that orion amp u using
2500D
you don't need that much power for the sub to reach full excursion though
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
someone told me a lond time ago our cars like 49-50hz so if you tune the box around 43-44hz then you can still play it for everyday use. if you tune any higher it will sound like $hit for everyday use.
with a 15"xxx and 2000 watts you should be at least in the mid 40's at the dash. what type of battery and what does your volts drop down to when you got the 138?
here is everything thing in the car.
up front battery - yellow top otima battery
trunk battery - red top
0 gauge to amps
210 highout alt
jvc headunit
1 farad cadence cap
volts stayed at like 12 but dropped to like 11 volts
you should have that red top under the hood if your using your batteries seperate. stick the deep cycle in the trunk.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
ok. whats the 2500d amp go for?
wysiwyg
that video of the xxx truck is sick. i wish and thats what i want my car to do...
