Since im using so many LEDs going to a switch, will i have to be worried about thermal runaway, if my voltage jumps around between 14.4 and 12v?
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
guess this has never been asked before.
I don't think anyone can answer accurately without having more information on your led setup. Just could hook it up and if you start to see failures, then look into getting a current regulator.
Your voltage fluctuation isn't what you should be worrying about. Thermal runaway is caused by an overcurrent condition, where the LED's are in a circuit formation to allow for a high current situation. If you want to prevent overcurrent, then you should use a current limiting resistor.
If you insist on overdriving your LED's, try soldering an aluminium heat sink to your negative leads to dissipate the heat faster.
<img src="http://img78.photobucket.com/albums/v290/americonium/Heavy_weight.jpg ">
Thanks abe, i really didnt know.
