So I'm stupid. I'm sorry
Can someone PLEASE help me???
Here's what I have...
A 2005 Sunfire... 1SV Base Base Base package.
I have a Sony MEX-5DI CD player with Sony Wiring Harness, then the $15 GM Wiring Harness plugging into the stock radio wiring.
I DON'T WANT THE DAMN CHIMES ANYWAY.
Here's what I've done... I have connected the black wire to black wire and bolted it to a ground (a bolt at the edge of the radio housing in the back). Red wire to Red wire. Yellow wire to Yellow wire.
Thats it, as I've got 3 amps and 4 sets of Components going in next.
WHY DOES THE RADIO NOT TURN ON?
The $15 wiring harness said something about a separate red wire I needed to attach to a fuse box??? WTF???
Whats going on?
ANY HELP PLEASE IS APPRECIATED!
"About Buddha: Just how in the hell does a 600-lb fat man have the nerve to preach about self control???"
Anyone?
read the sticky post up on top. it's more than a simple plug and play for you guys. with my wife's 02 i had to pick up the geo harness and use the wiper for power.
yep, gotta run a wire to an accessory power wire and connect that to the switched power (red) wire on the harness
-Chris
you have no switched 12v source in your wire harness. you can tap into a brown wire in the loom above your hood release, or you can use a fuse-tap (sold in autozone, pep boys, etc) and tap from your windsheild wiper fuse. both work just fine, dont let anyone tell you otherwise. ive got a guide online on a full install from start to finish, link is somewhere in the sticky.
this useless post brought to you by the alcoholic known as LUNDiS
