I have some new stuff for my 03 2door cavi..and want to trick it out alittle in the trunk
2- Almani 12" ALWB12
Max Power: 1000 watts peak
500 watts rms
3" black kapton voice coil
Recommended sealed
Enclosure range: 1 to 1.5 feet-cube
Free Air Resonance(Fs): 33.8Hz
Electrical "Q" (Qes): 0.62
Mechanical "Q" (Qms): 4.62
Total Speaker "Q" (Qts): 0.55
Equivalent Compliance (Vas): 1.36 cubic Feet/ 40.4 Liters One-Way; Linear Excursion (Xmax) * : 0.64 in /15.8mm Efficiency (IW/Im) **: 85.8dB SPL Effective Piston Area (Sd): 78.2 Sq. inch / 0.051 Sq. Meter DC Resistance (Re) ***: 4.0 Ohm Nominal Impedance: Single 4 Ohm Power Handling continuous): 500W Mounting Depth: 7.4 Inch / 181 mm
Mounting Hole Diameter: 12.0 Inch / 295 mm
Driver Displacement: 0.089 Cubic Feet / 2.45 Liters
* Xmas specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency ( IW/Im) is not an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other subwoofers to determine which one is "louder"!
*** Re (DC resistance) is measured with the voice coils in series, for parallel-wired specification divide Re by 4. All other specification remains the same
2- Almani ALCH550 amps
Power Output:RMS 275Watts x 2ch (@ 2ohm)
Bridge Mono RMS: 550Watts x 1ch (@ 4ohm)
Frequency Response: 15Hz-30KHz
Built-in Short Circuit & High
Temperature Protection
Bass Boost
Minimum THD 0.05%
LED Indicated Power Status
Mosfet DC
Variable Low Pass Filter
30Hz-250Hz (3/4ch)
Variable High Pass Filter
50Hz-1KHz (1/2ch)
High & Low Adjustable
Temperature Protection.
Also running 2 almani 500wat 6x9s and 2 almani 300Watt 4x6's
with aclh600 for 6x9s and alch400 for front 4x6's
http://www.almaniaudio.com/about.asp
I am wanting to know if you guys could figure out a design for my car..i can do fiberglass and all that..just out of designs..and figured it would be good to hear from you guys
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
btw..i like to race sum times..so cant be too heavey..the equipment it self is heavey enough~LMAO~
none has any ideas about a set up in my trunk?
How much did you pay for all of this?
around $1000..why?
My friend is a rep for them so i got it at discount ya know
