amp - Audio & Electronics Forum
amp
Tuesday, June 14, 2005 8:17 PM
Turning my s13 track car into a daily driver.
Alpine CDA-9830
Polk Audio db 675
6-3/4" 2-way Speakers
recommended power range 6-60 watts RMS
peak power handling 180 watts
frequency response 35-22,000 Hz
sensitivity 92 dB
Polk Audio db6500
6-1/2" Component Speaker System
2-way crossover network (4,000 Hz, 12 dB/octave)
tweeter protection circuitry
frequency response 40-23,000 Hz
recommended power range 10-100 watts RMS (300 watts peak power)
sensitivity 92 dB
I have an old 10" sub, I wanted to know if i could run one amp safely for all 4 speakers and the sub.
Thanks
Re: amp
Tuesday, June 14, 2005 9:46 PM
yes you can as long as you get a 5 channel amp
Re: amp
Monday, June 20, 2005 3:47 PM
Thoughts on Kicker KX700.5
70W x 4 + 210W x 1
http://www.cardomain.com/item/KIC04KX7005
Re: amp
Thursday, June 30, 2005 10:22 PM
im running a kicker 200.4 and a 1200.1 and i love them both the 700.5 will be more than enough power they under rate there amps allot my old 800.4 was rated at 100x4 (800) total it put out 1457 plus they come with an outstanding built in crossover
Re: amp
Friday, July 01, 2005 5:36 AM
run your rear speakers off the headunit, get a good 4 channel amp to push the fronts and bridge the back to the sub.
Re: amp
Saturday, July 02, 2005 8:14 AM
sndsgood wrote:run your rear speakers off the headunit, get a good 4 channel amp to push the fronts and bridge the back to the sub.
if you run the rears off the head unit they wont be balanced with the rest of the speakers plus they will be more likely to distort because the built in amps in the head units are not that great no matter what kin of unit it is best bet is to have all speakers amped so you have more control of the sound
Re: amp
Saturday, July 02, 2005 12:25 PM
the rear speakers should only be used for a little fill or not at all for a good sound stage. So the 4ch amp would be fine. another options is running the rear channels in trimode.
09 HHR LS, Wife's Car
05 Cavalier, Clarion DXZ375MP, Autotek MM8000.5 & 13Kv.2, wife's old car, updates coming soon
