i recently bought a panasonic headunit w/7 screen and dvd player. the only way i can get
a dvd to play is if i attach a wire to the e-brake. which wire is it? is there another wire i can attach it to so it will come on when i drive. i was thinking maybe an ignition wire.
can anyone help me out? thanks
if you connect it to the e brake wire the dvd player wont work until car is off and in park. theres ways around this... try searching.
<a href="http://www.liquidgeneration.com" target="_blank"><img src="http://www.liquidgeneration.com/quiz/images/crackaasswhiteboy.jpg" width="403" height="165" border="1">
You could wire it to the light on the dash that comes on when the e-brake is on?
Wire to your + wire going to the cig. lighter.
just ground the wire. that's all you need to do.
look in the manuel..whichever wire on the harness needs to be connected to the e-brake. connect it to ground instead.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
It needs to be connected to ur ebrake as a saftey feature so it can only be used while in park. But what everyone is saying is right, ground it, and it will work. If not, try a hot 12v source. BUT DONT QUOTE ME ON THAT. try ground first.
-- The The One One --
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
Thanks guys for your help. Sandmanx your idea worked...thanks bro!
just ground it, nuff said
