Ive got 2001 cavalier, I got my sub box for 2 10's almost complete, Just wondering what kind of set should be done with the power wire connected? Its a side post battery terminal, Should I just use a big O ring connector to the pos + post, then fuse with my run my 4 gauge power wire to my amp.?
any Idea's guys?
thanks.
You can get a GM post adapter, costs around $10 at BB or CC. You will remove the stock side post out of the positive terminal, and replace it with this, which gives you a terminal in which you can attach your power wire.
<img src="http://img78.photobucket.com/albums/v290/americonium/Heavy_weight.jpg ">
Awsome americonium thanks for the info.
