Need help wiring up fog lights with a relay - Audio & Electronics Forum
Friday, May 20, 2005 3:02 PM
I talked to viper about this a little bit...I got my relay, and I got wire.
I have a remote start system that's already tapping into my parking light circuit, which is what I planned on using for switch power to my fog lights.
85 - power
86 - ground
30-switch power
87-fog lights (+)
chassis ground fog lights
Re: Need help wiring up fog lights with a relay
Friday, May 20, 2005 8:10 PM
So whats you question
Friday, May 20, 2005 8:43 PM
hope this helps. found it on here.
Friday, May 20, 2005 11:32 PM
that's pretty much how I did it...before you posted the pic lol. Thanks for the help though...they work great!
Monday, May 23, 2005 2:19 PM
check the sig...they work
Sunday, March 12, 2006 5:06 PM
I have a 2002 Cavalier LS. I put a Z24 front bumber with fog lights on. I didn't have factory fog lamps so I attempted to wire them in. I used this diagram to wire it up. This a diagram supplied to the site by Kardain:
Kardain wrote:
Instead of wiring pin 85 to the fuse block; I wired it to the brown wire in the front corner lights.
Everything worked fine until the next morning. The left head light, the side I wired pin 85 to, started flickrering on & off about 4 times. Then a check wrench light came on the dash. I didn't have time to deal with it cause I was on my way to work.
So, when I got home I decided to disconnect everything and start over. The problem was that after I disconnected everything and wired it all back together, the same way as before, the fog lights wouldn't work. Though, they had previously. Started to get dark, so I disconnected everything and had to go to the store...
Now, my lights flicker on & off about 4 times, every time I start the car, and all my dashboards lights are gone. I still have a lighted digital odometer, radio display, rear view mirror lights, and dome light.
Anyone have any ideas what is going on with my car. I hope I didn't fry my BCM.
To add, I have done the DRL disable mod by grounding my dark blue wire to the BCM, to get my DRL's to stay off without having a check light.
Yes, I know this is a double post. Tthe other in exterior was an accident, trying to quote Kardain and somehow it posted it on that post.
Please HELP
