so i have 3 12" kicker comp VRs and 2 of them are in a sealed box right now,and im planning on making a 2nd box to house the 3rd sub,now i was thinking of making the 1 box a slot ported 1,would that sound like ass having 2 in a sealed and 1 in a ported box?i dont wanna build it and find out as its gonna be a fibreglass box and i dont wanna do things twice
some poeple told me not to do it but i jsut wanna make sure
having three subs is about as gay as it get's..
with that being said. pick either ported or sealed. you'll be much happier.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
hey wysiwyg
what makes having 3 subs gay? your gay for god damn saying it. be helpfull or get lost.
<img src="http://www.j-body.org/registry/blingblingfire/personal_pic.jpg">
the subs might physically play a little bit different, in which the subs could fight each other and be bad for sound and the subs.
3 subs is kinda gay you have to run a odd ohm load from the amp unless they are 6+6 or 3+3 coils and kicker dom't make them.
as for a box do a slot port box if done right it will sound louder and much nicer. if you want more s/q have the box tuned in the low 30Hz's or if you want more spl tune the box higher 40-45hz. call kicker up and see what the best box size for the subs you have.
if the subs are single 4 ohm your get a 1.33 ohm load if the are 4+4 you can get a .66 ohm load try to get a amp that does around 1000 watts at 1 ohm if they are dule voice coil or 1000 at 2 ohms if they are single.
BlingBlingFire wrote:hey wysiwyg
unless they are dual 6 ohm or dual 3...your gonna have a screwy load on the amp.
also 3 subs isn't gonna be hardly any different then 2.....fag
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
there 2ohm DVCs which should be at 1.34 ohms and my hifonics amp puts out 1000RMS at 1ohm so i think it will wokr out good
would a slot ported box have different calculations then the normal ports?cause i know if i use circle ports i would need anywhere from 5.25-6.75cubs which i dont see happening as i want teh box to be able to come out of my trunk
