feedback problem - Audio & Electronics Forum
feedback problem
Monday, May 02, 2005 1:50 PM
ok im getting the turn on pop and feedback problem only through my sub. I have made sure that the rca wasn't near any power wires and the for the grounding spot i have used in the past w/o any problems but im going to sand it down and try it again. the wired thing is when i have the fold down seat down and i move it a little but the noise changes freq., now if i press down on the seat a little hard it quites down but the noise is still there. I am using a audio control crossover i unpluged the rca from the in put and the noise cuts out completely. as far as the turn on pop noise i clueless on how to correct this problem. sorry for the long post hopefuly u guys can point me in the right direction. also i dont have a intrent connection so replys will be a little slow. thanks!
Re: feedback problem
Monday, May 02, 2005 2:50 PM
sounds like a pinched wire or something is wrong with your rca's(touching metal or something)
i would take a set of rca's..and run it straight from your deck to your amp....run it outside of the car just for testing
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
