I thought the ecotec did not have spark plugs, and since you have to have a colder spark for nitrous how would you acheive this?
Eco does have plugs, just not spark plug wires.. i think they are located under that thing that says Ecotec 2.2 or something. i maybe wrong though
yup they are under the cover that says ecotec
You have received a forum warning:
Warning: Foul language in the Chicago thread.
Expires: Saturday, March 26, 2005 6:07 PM PT
i would go with the autolite #103 plugs
ngk tr6 are also good plugs i had them in my 05 cavy w/ a 55 shot (zex)
i bought some TR6 plugs they are way too short a reach in the Ecotec head it is about 5-threads short and puts the spark down in the spark plug hole real far.
they are a little shorter then stock but they work fine I have had them in for 41,000 miles (changed every time change the oil) and they have all worked fine -- over 300 lbs of nitrous has gone through the motor
well i dont think i want them in my motor they are a good 6mm short . i put them in a head i have on the bench and the tip is way down in the hole with a bunch of exposed threads. . Guess i will just throw them in the tool box.
i use the denso iridiums for my ecotec they cost about 15 bucks a pop but they are the best for N2o i have the NOS dry shot system 75 shot
I've got NGK TR6 in my eco and they are a lot cheaper than 15 each, like around 2 a piece.
