my bottle heater is not coming on. i turn the bottle valve open and the pressure gauge reads 600 psi. so i go turn on the heater. from what i read if the presurre drops below 900 psi the heater kicks on. the heater does not come on. i tired everything i could think of. its still not coming on.
anybody have ideas?
check and recheck all your wiring.... of course
the next step would be finding out if the pressure switch is working.... you can either use resistance across the contacts or just check voltage on the load side of the switch to ground....
actaully i have some ideas to try. this NX setup sucks donkey nuts
that's wierd ive only heard good things from NX...
i checked the fuses. nothing wrong from what i can see.
im thinking its the heater itself
the thought came across my mind of getting a power inverter to plug into my cigarette lighter and wrap a heating pad around the bottle. but i dont think that will be a good idea
