I am thinking of doing the mod where you replace your IAT so it receives cooler air, thus creating more fuel. I found it in the library, and it says that it advances my timing 3 degrees. My ? is, with the added timing, would this interfere with a 50 wet shot? I mean, would they work in conjunction? I am a newb to the bottle, and I understand when adding nitrous, you want to retard timing, not advance it. But what is your thoughts?
98 z24, few upgrades, nitrous on the way!
put your iat in the correct spot.
Thanks for the quick response... What are your thoughts if I decide not to do the nitrous? Would it be ok to move it then? Like what kinda gains (if any) can I expect? I am running pretty lean now, I can tell due to my nasty lean pop from my intake and exhaust.. And from what I understand, doing this will add more gas into the engine.
It just makes you run a little richer,trust me I did it and it doesn't give you any gain at all.You have other issues if your running lean
Thanks...
Thanks.... Again! Haha!
