I was wondering about everyone's setups as far as those of us that have to tee into the fuel line .My setup consists of a brass fuel tee and a 6-8" piece of rubber fuel line that runs up to a small brass fuel filter that screws into the fuel solenoid.I keep having minor leaking issues and I don't have the high pressure hose that I should be using,does anyone have pics of a different type of setup for their fuel line?Maybe a steel braided line setup?Thanks
anyone?
I have a tap into the fuel rail and run a S/S line to the fuel solenoid.
thanks,
i was searching down a little bit and found some info similiar to that,I was busy watchin my kid so I didn't search earlier,
My profile has the link to my car domain page. On that page is a engine pic showing the fuel rail tap and S/S line to the fuel solenoid.
Hope it helps,
Don
What size/type of fitting is that tapped in your rail?Also what size drill/tap did you use?Thanks for any help given and sweet ride by the way.
Will check and post tonight
