I run a nitrous wet kit at 50 HP shot on my 2001 2.4L cavalier. Now I wanna push it a little more(like 75 or maybe 100HP shot).
I was wondering if there's any other retard timing module than MSD. I want to buy a retard timing module without buying the whole iginition control module(I just want to retard timing, nothing more).
Thanks!
Supposidley, the Greddy E-manage will let you change your ignition timing as well. You won't need to really attempt to change the timing till you reach a 100 shot though, you should be fine at 75.
The Emanage would only retard timing either all the time or none of the time.
To make it usable, you would need to write 2 programs and switch between them when you were going to use the nitrous or just regular driving.
The MSD DIS2 Programmable has inputs that will only retard the timing when the Nitrous is actually on and then instantly return to normal when it shuts off.
Driving around with the timing retarded for no reason = big loss of power, extremely high EGTs
sig not found
