well i posted awhile back i got a nos purge kit.. hooked it up to my co2 bottle.. and i cannot even see any smoke
people on here told me co2 would look the same as nos.. i have a 20z co2 bottle.. any suggestions do i need a bigger bottle or what do you guys think
i have a dual purge kit 20oz bottle.. no cloud
20 oz should be adequete.........does the solenoid work.......put your ear near it.........with the bottle closed and have someone else hit the button, if it clicks its ok, if not its wired wrong
if the noid works ok.......make sure the bottle is full, if it is, mabey you need a bigger botttle??? bu i thin a 20oz should be ok
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
ya everything works it clicks.. the button works but for some reason it doesnt really purge i see like no smoke ill refill the bottle n try again
Maybe it's the Tuner Gods trying to tell you something...
__________________________________________________________________
Performance cars do not win car shows and show cars do not win races.
It's up to you to decide which you'd rather win.
hmm, mabey ian.......but it may be a low bottle........may be that a co2 bottle has no pickup tube therefore won't work......a simpel answer is to swap the bottle wiht a nitrous bottle and see what happens.....then you know if its in the bottle or not
Hail Satan
well im sure its the bottle the valve works good i dont think the co2 bottle is big enough or lets enough co2 out imma try again tomorrow
You're barking up the wrong tree. You need to look at the physical properties of when no2 & co2 convert from a pressurized liquid state to a gaseous state and expelled.
phuk it im just buying a nos bottle..lol
Bottle pressure is a big thing when it comes to seeing the actual smoke. below 800psi you wont see most of anything, around 1000-1300 you should see a to of smoke though. This is through a 10lb nitrous bottle though
N2O + Bolt-ons
= 220Hp/
250Tq
Coming Soon:HpTunersPro, EagleConnectingRods, WiescoPistons, 13sec2200
