i recently purchased a ZEX  wet kit , NGK TR6 #4177 plugs gapped at .039 for my 04 sunfire. this is the problem , my fuel pressure is being cut after the initial "hit" of  WOT. What pump  is recommended whether it is in-tank or in-line
  you shouldnt need another fuel pump for any reasonable shot of n2o.
what kinda fuel pressure readings are you getting?
maybe you just need to turn off your traction control
um, if your fuel is cut, wouldn't the n2o kill your engine?
when the zex kit senses no fuel pressue , it will not release the n20 into the intake
when i tested it at work it primed at 60psi then it was idling at 54psi. when i ran the n2o at the track my boittle pressure was around 1000. will the zex kit not activate if bottle pressure too high ?
