Can anyone fix this - Image Manipulation Forum
Can anyone fix this
Friday, September 01, 2006 10:45 PM
wanted to do some photoshop work on the car only problem is is that part of the bumper is cracked up (had a racoon come across the road one night)can anyone fix it
http://i87.photobucket.com/albums/k156/EcotecSS/Frontend.jpg
Re: Can anyone fix this
Saturday, September 02, 2006 6:33 AM
Far from perfect but not too bad.
Saturday, September 02, 2006 7:13 AM
thanks man better then anything i coulda done
Saturday, September 02, 2006 10:37 PM
fixed the bumper and enhanced the picture itself.
Saturday, September 02, 2006 10:49 PM
To bad actual body work isn't as easy as these photoshop guys make it look
Saturday, September 02, 2006 11:50 PM
That's an easy fix actually, use masking tape on the outside of the bumper to hold it together and in place, 80 grit to the inside of the bumper/lip and then fiberglass across the crack, after u've cleaned it ofcourse.
Then on the outside remove the tape once it's fully cured and sand the crack, make a v shape in it. bodyfill the crack and block sand it where u can.
should be a days project.. a couple hours if you've done bodywork before.
80 grit - use for the inside of the bumper
120 grit - use for rough shaping the bodyfiller on the outside / making the V
220 grit - for smoothing the filler
400 grit - prep for primer
Monday, September 04, 2006 10:21 AM
BTW.....How big was that f*ckin' raccoon? lol
Monday, September 04, 2006 9:27 PM
basketball size plus i was going down a rural hwy at close to 70 mph in the boonies out here so i hit it and bang knocked his ass around not to mention i had something hit me getting on the on ramp to interstate 4 just south of disney world
