I have had a rear end issue, it feels as if the whole rear of the car is vibrating ever since I put stiffer struts and springs in. This is the second aftermarket suspension setup in the car so I know it is not that. I have tried different wheels and tires with no change. I thought maybe it was the bushings in the flex beam, but upon playing with things they appear to be tight. I have come to believe that the unibody is flexing badly as the suspension travels. Also it gets worse in warm weather.
Im going to do the Cadillac strut bar mod in the trunk and try to fabricate some kind of rear strut tower bar that will work with the top down.
Has anyone else with a vert experienced this?
Get a piece of lime 4" c channel and bolt it to the frame rails under the car. Similar to how an IRS setup is mounted. It should help reduce flex.
I do have plans of connecting the frame rails. need to repair some rust anyway.
Id be ok with doing some kind of roll bar but not a cage. Its a DD not a racer haha. Not sure how to do a roll bar and keep the top functional and still have a back seat though.
your going to have some flex with a unibody vert.
I have noticed that with the aftermarket suspension I have on my vert that the back end shimmys quite a bit. But I just chalked that up to being a Vert with no real structural integrity from the top. I have noticed tho, that its more noticeable in my vert VS my girls vert since her car is stock. Ill be watching this thread to see if there is something to do to fix this.
I'm glad to hear its not just my car. It didn't do this as as badly with stock suspension but it was noticeable. I am going to do some things to tie the frame rails together and make some kind of rear strut bar, if those things don't help then I will do a roll bar with several points in the back half of the car.
There was a reason why GM went high profile 15in tires and FE1 suspension on convertibles.
>>>For Sale? Clicky!<<<
