Wiring diagram - Third Generation Forum
Wiring diagram
Monday, January 25, 2010 5:52 PM
Ok I am putting cruise control on my 99 sunfire. I have everything but the harness for inside the car. If anyone know is the harness seperate? If no one knows that is fine I will find out tomarrow. But I need the pin out for the factory body plug. So I can see if i can hook the wires that go to the pcm there instead. The engine harness is a 97 z24 along with the pcm. The car is a 99 sunfire orginal 2200 auto. Thanks for the help.
Re: Wiring diagram
Tuesday, January 26, 2010 10:45 PM
Ok duh just realized it is in the link lenko posted. Just didn't know it because how it is labeled. So sorry about that. I got it all hooked up cept one wire that I am not sure what to do with.
Lenko can you give me some help with this. I have the white wire coming out of the cruise module. And have no clue what to do with it. The wiring diagram I am using labels it as Brake applied input. The link you have posted lenko the first picture doesn't show it. But the 2nd does. But I have no idea how to hook it up. Can I hook it to the body plug or am I going to need to plug it in at the computer? I would like it to be the body plug if at all possible. Just so I don't have to get to the computer agian lol. But I can if needed. Just not sure on the right wire at the moment there either.
Any help with the last wire? Thanks.
Re: Wiring diagram
Tuesday, January 26, 2010 11:04 PM
nvm I figured it out.I hook the white wire to the white wire coming out of the brake switch.
