quick question searched around some couldn't find an answer but will a 4 door sunfire gas tank work on a 2 door ? i think they're different aren't they ?
i just installed a plastic gas tank from my 2000 4 door grand am donor car( for my 3400 swap) into my 97 2 door cav. had to change a few things when it comes to the vents and lines and stuff, but i'm pretty positive the tank from the for door cav will fit the 2 door..if not which i doubt. you could always make it fit..lol..thats what i would do
[IMG]http://memimage.cardomain.com/ride_images/3/2977/3861/32441930001_medium.jpg[IMG}
wait wait wait
flatblakcav why did you do that if your running aftermarket gauges you may have just given yourself more headaches
98 and older js have a 0ohm empty 90 ohms full fuel sender
00 grand ams have a 40 ohms empty and 250 full
in CDN price for my gauge series 0-90 is 49 bucks and a programable (because they don't make a 40-250) is 169
if you have a 0-90 fuel gauge when your tank is empty it will read 1/2 tank also for the record 00 cavailers use the same pump as a grand am 97 grand am 3100 uses the same pump as a 2.2 cav (no point in switching) get a new steel tank and paint it before it goes in and you wont have an issue
look into that cause you may have opened a new can of worms
also 2 and 4 doors are the same tank sender is the same also from engine to engine
JBO since July 30, 2001
the reason was to replace the old rusted out steel cavalier tank that was leaking lol. but other than that its all hooked up to the grand am harness still..i changed over the full harness from the donor car.. the fuel pump seems to be working fine as well as the injectors ..just no spark
but does the gauge read properly with the sender???? the pump will run almost every GM car can runn off that wiring its how your gauge reads your fuel level
it shows 1/4 tank and i think thats about wat it should be i put $15 in it..gas is expensive here too soo
NOTa2_4 wrote:wait wait wait
so your sure the 4 door tank will fit my 2 door ?
YES
