dash problems.... - Third Generation Forum
dash problems....
Monday, August 31, 2009 7:45 PM
Alright ever since i put the car together (i bought it torn apart) I have had dash problems. None of the lights work in the hvac or cluster. the blinkers dont work, they just make an insane noise. the washer spray doesnt work. the brights only work, i have no regular lights, my dimmer switch doesnt work and wont turn the lights on at all. I dont know if something is @!#$ up or not plugged in.... i dunno, any help??? ty
Re: dash problems....
Monday, August 31, 2009 11:52 PM
Is the negative hooked up at the battery tray, under the battery tray on the frame rail, and on the engine block?
I had similar problems when I was missing a ground under the battery tray... leaky battery spilled acid on it, the wire corroded and all hell broke loose.
Tuesday, September 01, 2009 5:08 AM
nope I have good grounds. One from the Neg side of the battery to the frame. thats a 4ga less than a foot long, And one from the frame to the tranny bolt where it went to begin with (battery is in trunk). If that helps
Wednesday, September 02, 2009 11:36 AM
ne help????
Wednesday, September 02, 2009 7:24 PM
check your fuses, and then check the levers on the steering wheel. check all connectors
Thursday, September 03, 2009 5:08 AM
i havnt checked to see if the column is bad yet byt my fuses and connections are good
