transmission in a 01 - Third Generation Forum
Tuesday, July 21, 2009 9:27 PM
How many bolts hold the tranny to the motor? It is a auto. Thanks
Re: transmission in a 01
Tuesday, July 21, 2009 9:42 PM
6 on the bellhousing, 5 on the tranny side and one PITA bolt on the backside going in from the passenger side. Its easy on a 5 speed, but i always found it a pain on the auto. Dont forget the torque converter bolts.
Tuesday, July 21, 2009 10:10 PM
the three going into the flywheel? I got them Where are the 5 bolts at on the tranny? I go for off.
Tuesday, July 21, 2009 10:14 PM
if the motor is stuck to the tranny what is the best way to separate them? Thanks
Tuesday, July 21, 2009 10:32 PM
I got the one under the distributor, the one to the left and right of it, the nut off the stud, the one that came off as a stud. It was mostly eight-teen and one 15 size bolt. does that sound correct? Thanks for the help.
Tuesday, July 21, 2009 10:51 PM
Yes some are studs like that, all of the 6 bolts are 18mm they are all located around the bellhousing where it connects to the engine. These engines dont have distributors so I'm not sure what you're talking about. The 3 on the flywheel are the torque converter bolts. Then there are 6 bellhousing bolts, they are all in plain sight except the one at the back that goes in from the other side. You may have to shuffle the wiring harness out of the way to get at the top few.
Wednesday, July 22, 2009 8:52 AM
i meant the coil. I am use to the old cars, so i am used to saying distributor. Are some of the bolts on the bottom?
Wednesday, July 22, 2009 10:14 AM
im not an administrator but u shouldnt post in more then one section. just sayin so u dont get flamed at.
Wednesday, July 22, 2009 10:27 AM
I now, but I figured, I would try both sections, because I figured some people may know, but not look in both forums.
Wednesday, July 22, 2009 11:34 AM
do I have to remove the stud under by the coil before they will separate? Thanks
Wednesday, July 22, 2009 12:40 PM
The motor and tranny are unbolted, but the motor won't separate. need help.
Wednesday, July 22, 2009 3:06 PM
U gotta be missing a bolt somewhere, get a fresh pair of eyes their to double check your work for ya.
Wednesday, July 22, 2009 3:26 PM
I have, I have 6 bolts.
Wednesday, July 22, 2009 4:12 PM
theres 6 trans bolts there 18mm, 3 up the front 3 up the back however 1 hass to be removed from under the car or with a bunch or extensions on autos
3 Torque converter bolts (you will have to spin the flywheel to access them all
then theres a bracket on the back under the coil no idea how many it holds
you should have 6 large bolts
3 small ones and a couple medium ones from that brakcet
the fron bolts (large ones i think 2 of them have engine ground cables hooked to them)
JBO since July 30, 2001
Wednesday, July 22, 2009 9:22 PM
i got it
Wednesday, July 22, 2009 10:33 PM
I just remembered I forgot about the stupid bracket at the passenger side of the tranny attached to the block around where the passenger side driveshaft goes in the trans. Only the autos have it, I'm used to the 5 speed.
Thursday, July 23, 2009 5:18 AM
that bracket is what was holding me up.
