Dash Lights Not Fully "bright" - Third Generation Forum
Thursday, February 19, 2009 7:07 PM
Ok heres my problem: At night when i turn on my dash lights, the speed odometer section of light does not fully come one "bright" its on just not a bright as the Fuel level, and Rpm gauge, also the temp gauge has the same problem.
I checked the fuses, cleaned the terminals on the battery, checked my ground terminals on the block seemed clean. I'm at a loss what else to check, also a wiring diagram would be great too. Its for a 2000 cavalier 2200,4dr. Please offer some advice
Re: Dash Lights Not Fully "bright"
Thursday, February 19, 2009 7:33 PM
smack your dash. just above the cluster.
Thursday, February 19, 2009 8:15 PM
Bulb in cluster.
Thursday, February 19, 2009 9:41 PM
TheSundownFire wrote:Bulb in cluster.
car is a 2000. it has soldered leds.
Friday, February 20, 2009 8:01 AM
burnt out LED.
GL soldering a new one....probably cheaper to get a new cluster.
Saturday, February 21, 2009 8:33 PM
Does anyone knwo if a 2000-2003 sunfire cluster will work, only difference is the positions of the fuel and rpm tachs, are in different spots. Im thinking about buying a new one????
Saturday, February 21, 2009 9:50 PM
^Yes
Tuesday, February 24, 2009 5:49 AM
Ok i installed a 02 cavy cluster and all the lights work!!! Cleaned all the negative grounds, and wow what a difference. Only problem is that the odometer doesnt light up, you can see the numbers but it doesnt illuminate. Oh well it looks great.
Tuesday, February 24, 2009 1:52 PM
Rich Grayo Jr. wrote:smack your dash. just above the cluster.
