2200 sfi - Third Generation Forum
2200 sfi
Sunday, September 28, 2008 6:00 PM
hey i just have tw simple questions if someone who knowsmore than me could help me out it would be great
---is a 2200 sfi in a 2002 the same motor as a 2.2 in the 95 to 99s
---and is it worth the truble to swap fo an ecotec for the amount of power you gain?
Re: 2200 sfi
Monday, September 29, 2008 8:35 AM
yes and no
it is the same motor in the 98-99 but not the 95-97
98-02 are all the same
96-97 are the same
95 is by itself
you can swap a 96-97 into a 95 but you can't swap a 95 into a 96-97 since the 95 block doesn't have a Cam postion sensor
you can swap a 2200 into the 95-97 however there is a bit of wiring to do depending on WHAT year it goes into
as for eco depends on the year 2000+ are drop in 99 are little harder but since the evaps in the rear thats 1 less thing to dink around wiht but the 98 and older isn't any harder then a 99 just have to either move the evap to the rear and get a new line kit or just leave it in the front fender and wire it up and add the line theres a tread that breaks it all down
as for worth it depends if you want power then 100% worth it if you want reliablility NO its not both motors are extremly reliable and i would stick with what you got but the eco gets more power easier then a 2200 does
JBO since July 30, 2001
