need idea for thing to check ...missfire problem - Third Generation Forum
Sunday, June 08, 2008 8:09 PM
Hi, i go a problem with a 96 cavalier auto 2.2l...The car run very rough at idle ( like if he run on 2 cylinder only) sometime it backfire at the intake... and it impossible to reach 20 mph with the car the engine is missfire... I check all the firing side of the engine ( coil, plug, wire) everything ok... i do a balance test on the injector everything ok...fuel pressure ok.... egr ok...i do a compression test ( 150 on all the cylinder).. i check the engine vacuum with a vacuum gauge and i got only 10 inch hg when its suppose to get 18-21 ing hg.. i check all the rocker pushrod .. everything ok....
i need some idea to what to check next or help if thats ever happen you.. do you think the timing chain timing can be bad? i dont hear a chain click....
HP sell car, Torque win race
Re: need idea for thing to check ...missfire problem
Monday, June 09, 2008 11:06 AM
Did you check the plugs for cracks?
Monday, June 09, 2008 3:17 PM
sounds like the cat converter is plugged. unbolt the exhaust before the converter and see how it runs.
01 cav w/01 3400 gam gt 4t45e
