electrical problems - Third Generation Forum
electrical problems
Saturday, June 07, 2008 12:18 PM
yesterday i pulled all my carpet out of the car. i guess i pulled something loose under the dash but can't find it. i have a 2002 cavalier ls sport with the 2.2 ecotec. the problem is that my headlights, fog lights, and front turn signals don't work now. i've checked all the connections under the dash and they seem fine and none of my fuses are blown. any information that can be given would be very much appreciated.
Re: electrical problems
Saturday, June 07, 2008 4:43 PM
look again, a connection that would involve all those would be around the left ( drivers) side of the dash
Saturday, June 07, 2008 5:45 PM
Maybe double check the fuses. It sounds like maybe a common ground wire. Look closely.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
Saturday, June 07, 2008 6:20 PM
ok thanks. i also just found out my horn and wipers don't work neither.
Sunday, June 08, 2008 7:15 AM
I dont think its carped related. check the ground under the battery on the inside of the frame rail. often it becomes corroded from battery acid leaks. that is the common ground for all of the items that you mentioned.
01 cav w/01 3400 gam gt 4t45e
Sunday, June 08, 2008 7:49 AM
ok, thanks!!!!!!!!
Sunday, June 08, 2008 4:35 PM
FOUND THE PROBLEM. THE PLUG UNDER THE BATTERY TRAY HAD COME APART! THE TAB THAT HOLDS THE CONNECTION TOGETHER HAD BROKEN OFF BECAUSE OF BATTERY ACID! THANKS AGAIN FOR ALL OF THE HELP AND ADVICE I HAD GOTTEN ON THIS PROBLEM!!!!!!!!!
Monday, June 09, 2008 3:25 PM
yeah that ground splice pack is a piece of crap, mine screwed up too. do yourself a favor and cut the whole thing off and put a couple of ring terminals on .
Tuesday, June 10, 2008 1:01 AM
sounds good! thanks!
