i own a 1996 cavalier z24 2.4 twin cam i wanna put the 2.3 quad cam in it but when i search the specs ....the 2.4 has 150 hp and 150 tq the 2.3 has 150 h.p and 145 tq so which engines come with 180 or 190 h.p?
the W41 Quad 4 is 190 the HO Quad 4 is 180
which car do i find those engines in.....and does it bolt up to a 96 z24 does the ecu work?
no the 96 ECU does not work the 96 is OBDII where the 95 older is OBDI
you can find the engines in the Beretta GTZ, Olds cutlas calais W41, Olds Acheva SCX, the 442,
so what do i need to make it obd1 and will the engine bolt up to my motor mounts? what about the tranmisson
