2200sfi piston and rods - Third Generation Forum
Saturday, May 17, 2008 10:40 AM
hey need some one to help me??????please can anybody tell me how to id. pistn and rods for this car????is it like the roller rockers and you can take a set for the 350 small block...narrow bodied self aligning 1.6 ratio 3/8" stud.....so on and so on..lol ...is it like this or am i stuck with madfor 2200 parts..??????...please help.....also if you know about the eagle crank and how to id. it or how to find one for it..?????thank
Re: 2200sfi piston and rods
Sunday, May 18, 2008 5:17 PM
help please???
Sunday, May 18, 2008 7:06 PM
There are no aftermarket cranks for this motor. The stock crank has proven reliable up to 350 HP + on a few boosted motors.Unlike most V design motors, which have a main bearing saddle between each pair of rod throws, you have a main bearing saddle between each rod throw. That's twice the support on the crank.
The rods are a one-shot-forging, which are pretty decent. The rods will handle mild boost or the stock rev limit N/A. If you were to turn upto 7000-7200 rpm momentarily, some moderate work to the stock rods and they'll be fine. Anything more than that, then go with the Eagle Rods or custom forgings.
Stock or stock replacement pistons are good to the stock rpm limits and or mild boost, anything more get a set of forged pistons.
Monday, May 19, 2008 11:43 AM
and by the wording of the op, you can not go buy a set of pistons for a sbc, and use them. the rockers will work, but nothing internal.
what are you planning on doing with the motor? that might help someone give you more solid advice, but i agree with most everything mad jack said above.
Tuesday, May 20, 2008 1:50 PM
im planing on force feeding her or a strong shot ov nitrous........do you know how mutcn n20 the 2200 can take b4 you have to start messing with the fuel and what spark plugs at what shot??????????id like to go the nitrous rout but what hase to be done for the 2200 to take a hard hit and can it handle a 30 or 50 shot on stock fuel pump and intenals??????????i thought iv sean eagle cranks and piston for this car but i cant find them.....i no madjack is rite i just thought iv sean them......
Wednesday, May 21, 2008 6:35 AM
no crank....but the crank in the ln2 is rather stout, and shoud handle your nitrous fine. You need to research what you want to do more than just "i wanna cram nO2 down her throat"
The amount of nitrous you can run without any fuel mods safely is 0
I am not a bottle guy, but I know you need to make sure you do it right...or pay the price.
I would not consider 30-50 shot a "big" shot at all, and you can probably run them with little mods, on the stock fuel pump. But i doubt that will give you the results you are looking for. I would suggest you hit up the nitrous forums, as they will be able to give you some more specfiics on thier set ups, and what works good for them, and what thier results are.
Wednesday, May 21, 2008 10:40 AM
i know that 50 is not a big hit i was asking what can be done on stock set up....im hoping for 150 shot with some work....i dont know im into boost also but its cheaper to spray and pray.........id love to have a 15 psi 2200.....$$$$$$$ but is worth it.....
Wednesday, May 21, 2008 10:47 AM
my reasoning was once you buy the turbo kit....you bought it. Nitrous you need to fill all the time, if you plan on using large amounts, it is more cost effective to go turbo.
You are going to need a lot of upgrading to run a 150 shot.
Thursday, May 22, 2008 5:41 PM
2200SFI JBODY wrote:id love to have a 15 psi 2200.....$$$$$$$ but is worth it.....
Yes it is
P&P Tuning
420.5whp / 359.8wtq
Friday, May 23, 2008 10:37 AM
hey when you put roller rockers on the 2200 is it the breather on the valve cover that you shave a little????????????
Friday, May 23, 2008 10:43 AM
no, it is an oil baffle.
Saturday, May 24, 2008 9:32 AM
ware is the oil baffle?????.....i thought i read that i take the baffle out and then i grind or cut the breather on the inside of the valve cover ...?????......if you go to howell the link dosent work.....can anyone give me a pic of what i am to do??????????????????please ...?????..thanx
Saturday, May 24, 2008 12:07 PM
The oil baffles are the inside parts of the breather and PCV valve assemblies, the breather and PCV valves are the outside parts. The oil baffles keeps the oil from being sucked into the PCV valve and out the breather.
Saturday, May 24, 2008 9:11 PM
bad ass.......thanx......hey jack i looked at your list of rockers and thats how i found the parts that i need .....after i got it all i added up all the money and it came to $$$423.67 with ship.....thats everything ..push rods,rockers,studs and valve cover gasket...its cheaper to get the gold set from howell....you get it all butt the gasket for$$$ 224.24 + gasket ...i even got the proform rollers one at a time from jegs at $16.99+9.99 shipping that came to $26.98 each.......i just thought i wold tell everyone that it did look like the cheaper way to go and in the end its not.......its still a good list of parts and its cool that you put it together for use....thanx..p.s. it is varey good to know
Monday, May 26, 2008 6:27 PM
thanx
Monday, May 26, 2008 7:06 PM
2200SFI JBODY wrote:bad ass.......thanx......hey jack i looked at your list of rockers and thats how i found the parts that i need .....after i got it all i added up all the money and it came to $$$423.67 with ship.....thats everything ..push rods,rockers,studs and valve cover gasket...its cheaper to get the gold set from howell....you get it all butt the gasket for$$$ 224.24 + gasket ...i even got the proform rollers one at a time from jegs at $16.99+9.99 shipping that came to $26.98 each.......i just thought i wold tell everyone that it did look like the cheaper way to go and in the end its not.......its still a good list of parts and its cool that you put it together for use....thanx..p.s. it is varey good to know
you are very hard to read lol
Tuesday, May 27, 2008 11:18 PM
o.k. cool
