anyones car spit and sputter taking hard corners? - Third Generation Forum
Wednesday, March 12, 2008 4:45 AM
In a straight line it never happens but when I take a corner at low speed and hit the gas it spits and sputters. Even with a full tank. What the heck.
99 cav 2.2L 212,000 miles
97 cav 2.2L 110,000 miles
91 cav 2.2L 236,000 miles RIP
04 Silverado Z71 Ext.Cab 55,000 miles
01 Suzuki SV650 22,000 miles
97 Arctic Cat ZRT 600 6,000 miles
Re: anyones car spit and sputter taking hard corners?
Wednesday, March 12, 2008 6:13 PM
damn man we just talked about this in class today...i can't remeber the answer i'll post if i can remember
Thursday, March 13, 2008 4:49 AM
Check your oil.
The O/P switch opens when pressure drops below 6psi, well the switch being closed allows power to the fuel power, being open, no power to fuel pump, so a quick second loss of O/P would cause this, the reason it happens around turns is because all the oil sloshes to one side for a second
Seen this happen quite a few times before
Thursday, March 13, 2008 6:38 AM
^ no kiddding.. I could see that happening. Thanks for the information!! I am slightly over due for a change so I will do it today at lunch time. I will report back.
Thursday, April 03, 2008 1:27 PM
Sorry its taken me till april. I moved and had no internet.
I changed the oil and no difference. Today it's doing it worse than ever especially from a stop. If I stop then hit the gas, it spits and sputters then goes.
I am wondering. It has a new fuel filter and plugs. (well they have 3,000 miles on them). I have ran injector cleaner and dry gas thru the tank.
It is not kicking any codes. Even when it almost stalled today no codes.
Hmmm.
Friday, April 04, 2008 10:55 AM
I seafoamed it in the tank and in the vaccum line to the injection.. The car didn't smoke like sea foam said it would.
Anyways no difference.
I purchased new Bosch wires today for it and will get them on this weekend. 30 bucks for those.. didn't get the cheap ones this time, maybe it makes a difference.
Friday, April 04, 2008 12:48 PM
fuel filter
Saturday, April 05, 2008 5:19 AM
Matt
Just a thought--may not be your problem.
I can vaguely remember a posting similar to yours, the fault turned out to be the injector harness being chaffed by the steering linkage somewhere under the car. It only happened when turning corners.
Routing correctly and repairing the wires fixed the problem.
Alont
Monday, April 07, 2008 5:51 AM
PROBLEM SOLVED
Plug wires
Dont know how or why. 2 years ago I bought the car with 63,000 on it. I put in new plugs and new wires just to tune it up. At 85k I started to have the issue. New plugs, issue went away. Now with 88k, issue back. So I thought maybe moving the plug wires helped them not touch somewhere. Taking corners would move them a little (maybe just enough to arc something)
So I went and bought new bosch ultra premium. Problem solved. Starts easier, idles perfect now without missing a beat, runs perfect with no hesitation. I drove it all weekend and it did not do it once.
Now.. I am going to advanced autoparts and they are refunding me for the wires because they were under warranty.
Never buy Autolite Professionals.
Thanks J-body fans.. You rock.
I am starting to get into this forum, even though I don't have any interest in moding my j-bod at all.
I like the J-bodys so much my girl needed a new car. I got her to buy a new 4-door cobalt. She loves it!
Monday, April 07, 2008 7:04 AM
Cobalts are not Js, they are Deltas completely different.
I would get some of the black wire loom stuff and put over your plug wires to help prevent them from rubbing threw.
Monday, April 07, 2008 10:19 AM
^ I don't know anything about the new cobalts. I assumed they were the new cavalier and designated j-bod
I put the wire loom stuff back on them when installing.
found this cool site on GM's site about my car also
http://media.gm.com/division/chevrolet/products/archive_prod_info/97chevy/cavalier/index.htm
