im lookin for an 03-05 cavalier with a manual transmission, i need basically the transmission and ecu, gauges, pedals, and everything to complete a transmission swap, also if the motor is there i wouldnt mind taking that too to bore it out and getting bigger pistons, thanks
I have an ecotec sunfire gauge cluster if you're interested.
hmm, is it for a manual car?
because i heard i needed to change the gauge cluster when i swap the transmission
dont quote me on it, but i thought all of the 03+ Js used the same cluster.....like they all had a tach.
NO SIG FOR YOU!
ya but i heard that you need to change the cluster...im not sure thought because its the same exact thing
00-05 clusters are all the same, and interchangeable. You don't need to swap it when you go to a manual transmission.
The mileage is not stored in the 00-05 cluster... it's in the BCM. So as soon as you start the car, after swapping clusters, you will get the proper mileage displayed.
John Lenko wrote:00-05 clusters are all the same, and interchangeable. You don't need to swap it when you go to a manual transmission.
Yes.
But the Sunfire and Cavalier clusters differ. The Sunfire cluster has a larger tach (which is why I bought this one) but I never got around to installing it and I'm sick of having my dash apart because I'm lazy.
True.. there used to be a Sunfire cluster in my Cav too
I just liked the fact that it's more balanced.. uses the cluster space better than the Cav does. But to the OP, you don't need to change the cluster.
hmm ok...well i found this car on ebay for 500-1k dollars and im not sure if i should buy it, its an 03 cav, but why on earth is it that cheap if its supposedly good as new, with only 43k miles on it...
i dont know, wheres the best place to buy parts for a swap at?
joe malechowski wrote:http://cgi.ebay.com/ebaymotors/CHEVROLET-CAVALIER-LOW-MILES-SUN-ROOF-CHEAP_W0QQitemZ150193104267QQihZ005QQcategoryZ6163QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Two words , Salvage title. A branded title will easily be worth 1/3 less than a good title car. Plus on that one, It was 1950 when I looked, they may yank it off at the last min.
Reguardless of the price If your in the market to buy , dont buy a salvage unless you know what your looking for in poor repairs. Just because its inspected means nothing in reguards to repair quality or safety. The inspection for a salvage title is only to check for stolen parts and create state money from the inspection.
oh man thats the same cavalier i was looking at...it was at 500 when i first saw it which is what made me want to buy it right away...
but now its over 2k and i dont have that amount of money...
i wish i could just buy a car for cheap, under a grand, which i know would be near impossible to find my model for that cheap but, ya and i'd just swap everything out of that car to mine!
