I have a 98 sunfire gt and the motor and transmission is gone. I was wondering what kind of motor and transmission can i get with out to much screwing around with it. the old motor was a 2.4 and a standard. i was wondering if it mattered on the year or what kind of car (sunfire or cavy ,etc) i was going to go towards a 2.2 automatic because it would be more easier for me to find.
please help
thanks for your time and input.
spandex is a privilege not a right
www.car-part.com is your friend when searching, it will search all the national salvage yards for you.
what the rest said, stick with the 5 speed tranny. Also, If I were in your shoes, I'd stick with the 2.4 as well. To swap a 2.2 in there isn't going to be that easy. All the mounts are different, as well as the trannies. If your not afraid to spend a few dollars, I'd suggest hunting down a used tranny with low miles, and rebuild the 2.4
Michael Antle wrote:what the rest said, stick with the 5 speed tranny. Also, If I were in your shoes, I'd stick with the 2.4 as well. To swap a 2.2 in there isn't going to be that easy. All the mounts are different, as well as the trannies. If your not afraid to spend a few dollars, I'd suggest hunting down a used tranny with low miles, and rebuild the 2.4
well i was going to buy a parts car that i could take the motor and tranny out . Also it's kind of hard to drop a few dollars when your a high school student with no job.there is no motor in it anymore so i can't rebuild it the motor was sold before i bought the car. I also may be able to get a 98 cavy 5 speed that i could take the motor and tranny out. having said that would i need to change over the mounts and all the other stuff?
you would only need to change the mounts if you get a different engine/tranny combination and if you change that combination your looking quite a bit of work to change wiring harnesses and ecu's.
for the whole situation it will be cheaper and easier to put a 2.4 with a 5 speed back in the car.
Thanks for all your help. If there is any more information that someone can tell please feel free to let me know it would greatly appreciated.
