loud clanking at 2500+ rpms - Third Generation Forum
Saturday, October 13, 2007 1:39 PM
i cant quite pinpoint a location its coming from and i checked the belt so its not just flapping around.
it is unnoticeable below 2000 rpms and it gets louder a i get higher in the rpms.
anyone have this problem or maybe know what i could check out?
Re: loud clanking at 2500+ rpms
Monday, October 15, 2007 6:41 PM
well i checked my fuel injectors and spark plugs today but they all seemed fine
except one of the fuel injectors had a small tear in the o-ring
also i added engine oil, i was low about a bottle.
im stumped!
could it possibly be my cams?
Wednesday, October 24, 2007 7:10 PM
Well, you have NOTHING in your profile, so that doesn't help anyone rying to diagnose your problem. But from the description of it, and guessing you have a 2.4L engine, I bet any money you have a bad rod bearing.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Sunday, October 28, 2007 10:47 AM
It could be a A/C compressor or the tensioner pulley. If your Lucky.. If your not, It could be a major engine problem. rods, valves lifter, crank shift, cam shaft, oil pump, or like Luke said. You will have to listen to where the noise i coming from. If it's in the front of the engine, or the back or the bottom of the engine or to the side.
Tuesday, October 30, 2007 5:51 AM
If I had to roll the dice.... I'de bet that your starting to throw a rod bearing.
Is there any chance you can post a vid or audio clip?
Sunday, November 04, 2007 5:52 PM
dude stop driving your car Ill be willing to bet Its your # 4 cyliner your nuts on your rod cap are backing off.
I just had to replace my motor about 3 months ago and I sill have all the pieces of my # 4 rod & piston.
I just cant drive 55
Monday, December 03, 2007 10:32 PM
What kind of clanking is it? Is it like metal sounding or a knocking?
