im looking to put a ecotec in my 99. i can get the motor and i am just wondering what tranny to put on the ecotec. im new to the ectoec as i have an 2.2OHV.
thanks
M62 KIT for sale PM ME
no way. i mean is a getrag or?
You need a Getrag transmission with the Ecotec bellhousing. That is a different bellhousing than the 2.4L, the base 2.2L pushrod (like your motor, which is why it won't bolt up to your transmission). You'll also need to cut out the rear transmission mount and weld in the new GM one... as well as modify the front trans mount (the mounts are different between the Isuzu you have and the Getrag).
Plus, to run the Ecotec.. you'll need the newer computer... which only works with the Body Control Module... and that means re-wiring the entire car.... swapping airbag module... dash to fit the larger cluster.. brake module for the ABS.. re-bend the brake lines..
Have fun!
...j
so i see that theres a lot of work. is it worth it?
lol its more than just getting the motor and dropping it in.
oh yeah i knew it would be more than just dropping it in. i didnt know about the dash and all that stuff
yeah that sucks that it isnt. oh well. i might just try to find a built up 2.2 and put that in. if anyone knows where there is one for sale pm me and let me know.
A 2.4 for your year would be a much easier swap, and makes comparable power stock to the Ecotec, and it has decent albeit not as good aftermarket support as the Eco.
