your fan relay is probably done for. had it happen to me. swap your fuel relay w/ your fan relay, turn on the ignition and the a/c, and see if the fan comes on.
the pcm should ground the relay, do you have all your grounds conected-- also- do you have a scanner to be able to manually turn on the relay??
quicklilcav...arnt your tires on backward? in your sig....or is it just me
just to make it easy so I don't have to search, what pcm - year and make, are using the stock fuse/relay under the hood, -- what did you wire into it??
OK, I don't have a 95 j body wiring, but-- you should have 12+ to the #30 and #85 at the cooling fan relay from the 30amp fuse from the under hood fuse center. If you ground the green wire- #86 it should turn on (with the relay in place)-- this should be wired to the new pcm cooling fan relay circuit
I did some searching, couldn't find 95 wiring diagram-- but 93 firebird used b2 for the cooling fan, 91 camaro used ge8, 94-96 cutlass and ciera used gc3
nice to hear your cars running. just waiting to have mine run again, what do you have left to do before you take it for the first drive?
My 3400 Swap Page
Don't feel bad, I did the axact same thing when I replaced the clutch in my 93 sunbird I used to have.
SO when are we getting those gruling open d/p videos?
nice work so far, i want to see this beast live.
Congrats man, good to hear.
