cam swap possible??? - Third Generation Forum
Thursday, March 01, 2007 9:44 PM
ok so my buddy has a 1996 cavvy w the 2200 dohc engine and i have a set of cams from my extra ecotec head layin around and he wanted to knw if he could just bolt those in and run it like that or if he had to re flash his computer....or if itll even work right because...correct me if im wrong...but u also have to use the ecotec cam gears on those cams and cant use the cam gears from the 2200. help ne one?????
Re: cam swap possible???
Thursday, March 01, 2007 11:02 PM
2200 only had one cam, and no the ecotec cams wouldn't work in that engine.
Thursday, March 01, 2007 11:32 PM
ok. quick history lesson. the 2.2 ln2 in the 3rd gen j's was run from 95-97. THEN it became the 2200 (almost the same engine, but not really interchangeable) in 98, and ran till 02. both were OHV engines, meaning single cam that was below the valves. lifters, pushrods, the whole 9. the DOHC engine was predominately the ld9 2.4, which ran from 96-02, with slight variations along the way. the ECO took over in 03, through the end of production in 05. now, between those three engines, you cannot swap cams. at all. ever. eco cams cannot go in a ln2 or ld9. or vice versa.
Monday, March 12, 2007 5:46 PM
Ive heard that the pre 98 2.2 ohv motor has a slightly more aggressive cam than the 98+ 2200's do... are those cams swappable? is that worth doing at all? (just a thought that ill more than likely never have again but i thought it worth asking)
Tuesday, March 13, 2007 9:18 AM
well, cam swaps in the ohv engines are really no small task. and for the amount of work it would take just to swap in another stock cam, i's day no, not worth it.
Tuesday, March 13, 2007 10:28 AM
nope
even if it was possible, the amount of work involved wouldn't make the 2 hp difference worth it at all.
the real honda killa...
ok so my buddy has a 1996 cavvy w the 2200 dohc engine blahblahablah ...correct me if im wrong...blahblahblah. help ne one?????
it won't work. As was stated, the old 2.2 is a pushrod engine which means the cam is in the block, and the only thing under the valvecover is pushrods, rockers, and the tops of your valves.
