Hey I just had a few questions, I'm gonna try to replace the CV shaft on passenger side of a 2001 cavi 2.2 but i need to know whether the tranny is a 3 or 4 speed and if i need aftermarket carrier bearring support or not.
I'm guessin its a 3 speed everything is stock and i don't ever remember the older cavis being a 4 speed but i could be wrong, any help would be great. I dont have the car here with me right now to find out so ya know...
and as far as the carrier bearrings go I'd also guess no on that, because its a stock shaft and I'd be replacing it with a OEM shaft. I could also be wrong with that too.... and once again cant go look right now.
So if anyone can help me out as to what to buy and maybe what to look for on the car to know. I'd appreciate it
Thanks
-Aaron
<img src="http://registry.gmenthusiast.com/images/silentbob/fullcar-crop.jpg">
"Anyone can make a Sig with Photoshop... Try usin' Microsoft Paint"
If your going to replace one, then just do both, cause not too long after you replace the pass. side then the drivers side will go out. So you might as well just do both at the same time. Thats what I did and everything has been fine.
alright cool, the prices were the same either way, so imma go with the 3 speed with no bearing support and it should work correct?
and as far as replacing both sides, we will see. the owner of the car got into a lil fender bender and it warped the shaft a lil which caused the wheel bearing to fail. so after replacing the bearings we realized that the axel needed to be replaced.
hope all goes well, any install tricks or tips ????
Thanks
-Aaron
4speed and 3 speed axles are not the same are they?
Rich Grayo Jr. wrote:yes. pull. hard. no, really. HARD.
HAHA ya i figured that much... we had a hellava time with the axel nuts the first time. and the starter bolts for that matter. snapped one of em in half.
imma take a look at her car tonight to see exactly which i need to get.
only thing im not sure of is the carrier bearings, but i'll figure it out.
thanks for the replys
-Aaron
Yea, definitaly pull really, really hard. And when you put the new one in, make sure you push it in hard enough so the little retaining ring clip is in the right place inside the trans.
alright im gettin the 4 speed without the aftermarket carrier bearing support. doin the install on sunday, i'll post back and let you all know how it went.
changin the plugs and wires too, no worries there though.... i hope. thats what i thought about the starter too haha
-Aaron
