I was wonder how hard it is to put a v6 into my 02 cavi (2200 5spd coupe). I've heard of people using the 3.8L supercharged engine out of a pontiac bonniville gtp or the grand prix. Whats the procedure? Any shops in alberta, canda that you would recomend? Thanks for the help.
search, it's there. believe me, you will get flamed
search raven..he did it and makes kits as well to help you along....you are right on the engine tho..as for shops in alberta not too sure but im sure raven will be a good help. If you dont have te mechanical ability to do it yourself with some guidance...not trying to be rude but it might not be the best route for you...just my .02 tho..phil
You need a shop to build you something like this... I purchased the motor mounts from DoubleZ, same guy (Brad) that made Ravens (James)
Oops......... here is the pic
