i have a 99 sunfire and it has a digital odometer but at times it dont show the correct mileage or it show the actual mileage as trip and the trip reset doesnt work but it changes between these symptoms while im driving has anyone else experienced this ? does anyone have any suggestions and could it be my gauge cluster is shorted or something ? speed , tach , temp , and fuel all work great just the odometer is whats all screwd up ! plz help me ? !?!?!
'99 2.2 OHV w/3spd auto (work in progress)
http://www.cardomain.com/ride/2322134
Bob did you check your Leds back there behind the speedo if that is the culprit your better off replacing the cluster with one dirt cheap from a Junk yard, because from what i have heard if the odometer starts screwing up you can't really fix it . HAHA i was going to say ecm for a minute but then i thought wait that doesn't have anything to do with the odometer
my odometer is a spaz, it like tweeks and flashes switches between trip and the milage, screws up the numbers to weird shapes. when i hit the dash above the odometer it usually fixes itself....i just havent gotten around to taking the dash apart to check the connection. It doesnt do it constantly only every once in awhile so i'm not in a hurry to fix it. It always goes back to the correct milage after a couple seconds on its own anyways. It doesnt really bother me.
Niteowl
I thought that the mileage was stored in the BCM. Is that a 96-99 thing with it in the cluster?
01 cav w/01 3400 gam gt 4t45e
I just fixed my spazzing out odometer in my 2000 sunfire gt. I just took the gauge cluster out of the car and snapped the back plastic cover off and then resoldered all of the pins for the odometer display. Works great now and it didn't take long to do either.
does your trip OD work now to b/c mine is fried with my regular OD spazzing out like it is my trip OD reads like 10000 some miles.
My Girlfriend O1 sunfire o.D spazz's out all the time..
The mileage is saved on the ECU in the 00+ cars. Anything before that is saved on the cluster.
Worst thing that could happen.... maybe you'd lose 30,000 miles.
Shooff yeah he might lose 30,000 miles, but then come trade in time isn;t that going to be a prob because with the odometer goofing up and the actual mileage not being there unless he could remember off the top of his head what it was .
You don't have to worry about mileage if it is 2000 and up.
Greg so if you have a 2000 and up J and your odometer says you have 120,000 on your car when you really only have say 60,000 and you go to trade the car in the fact that the odometer is incorrect theoretically will make no difference whatsoever.
